Can I read the voltage through stm32f401ccu6 and ST-LINK?
I'm going to use CubeMX, is there a way to measure the voltage input through STM32F401CCU6 and ST-LINK? I'd like to know an example code or method if there is
waclawek.jan
The short answer is, no.
The long answer is, theoretically yes, but it's unlikely anybody ever made the effort to do that.
KnarfB
ST-LINK has a TVCC pin for measuring the target voltage. You will find the value in the logs or STM32CubeProgrammer.
hth
KnarfB
AScha.3
Just to make sure: you want see supply voltage of target or voltage at a pin of target, by ADC of target CPU?
