C071: CubeMX is generating invalid code
When using USART2 on the C071, CubeMX is generating calls to functions like `HAL_UARTEx_SetTxFifoThreshold` but the USART2 on C071 is a basic UART without FIFO.
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @G565
Your contribution is much appreciated.
Issue has been raised to development team for fix.
Internal ticket number: 212488
I will keep you posted with updates.
THX
Ghofrane
Ghofrane GSOURI
Hello @G5658
First let me thank you for posting.
I'm currently investigating this issue issue .
I 'will get back to you asap.
THX
Ghofrane
Ghofrane GSOURI
Hello @G565
THX
Ghofrane
Hi, is there an estimate for when this might be fixed?  6.15 was released in July and still had the problem.
Is there a workaround other than hacking the generated code?  Maybe using ll_ instead of HAL?  The ll_ code doesn't have the check and just writes to the CR3 register bits, even though it has no effect.
Regards,
Mike
