Simon NOWAK
''C'' STM32 ADC Project to ''Cpp'' (CubeMX)
Posted on September 12, 2017 at 10:32
Hi everyone,
I'm trying to convert a 'C' generated project with CubeMX in 'Cpp' but I have some problems with that. Indeed with CubeMX I have generate a project to read ADC values. This one work fine. The same project converted in Cpp compile but the value of the ADC is always the same ( 0 ).
Do you have any idea where this problem could come from ?
Thank you for your help and for your time.
Simon
#stm32l0 #cpp #eclipse #adc #cubemx
Note: this post was migrated and contained many threaded conversations, some content may be missing.
AvaTar
Senior III
September 12, 2017
Posted on September 12, 2017 at 10:51
I would guess the interrupt routine names don't match.
C++ requires a extern 'C' to not mangle object names.
Simon NOWAK
Posted on September 12, 2017 at 10:56
So I have to add the extern 'C' on all the libraries in my project ?
Thank you for your help.
September 12, 2017
Posted on September 12, 2017 at 11:00
No, Specifically the IRQ Handlers described in the vector table, they are in an assembler file with weak linkage, you have to get the names right to use yours, the C++ names will be mangled.
And perhaps other things where the linkage fails.
