Morty Morty
Aug 21, 2018 8:16 AM UTC
[Bug] STM32CubeMx fails to update linker scipt when using Makefile as Toolchain
2018-08-21 10:07:21,259 [INFO] ToolchainGenerator:120 - stack trace : java.lang.UnsupportedOperationException: Not supported yet.
 at generators.MakefileGenerator.updateHeapAndStack(MakefileGenerator.java:315)
 at generators.Generator.generateLinkerFile(Generator.java:715)
 at generators.Generator.copyLinkerFile(Generator.java:407)
 at convertor.Convertor.generateMakefile(Convertor.java:1436)
 at convertor.Convertor.generate(Convertor.java:608)
 at convertor.Convertor.convert(Convertor.java:515)
 at convertor.Convertor.updateProject(Convertor.java:384)
 at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.update(ToolchainGenerator.java:114)
 at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:1780)
 at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:574)
 at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:41)
The even occurs if the stack was not changed, but running java from mingw/git-bash. This might be related to line endings as the linker script has windows line endings. However the ioc is saved with linux line endings when run from mingw/git-bash.
