Bug: STcubeIDE - CubeMX completely destroys project
- 7 replies
- 1132 views
I have a working project in Atollic 9.1 with the CubeMX 5.0 plugin.
I imported the project into STCubeIDE per instructions in UM2578.
The import process reported no errors.
The release config is gone - destroyed during import (see separate bug report here: https://community.st.com/s/question/0D50X0000AnuVOVSQ2/stm32cubeide-import-from-atollic-deletes-release-configuration)
However, the debug configuration properly builds and loads/debugs.
In the CubeMX perspective, I can open the IOC file from the project (written by the CubeMX 5.0 plug-in), but...
'Generate Code' completely obliterates the entire contents of the project (everything is deleted from disk and IDE).
To help you debug this problem, the IOC file is attached.
Are you aware of this problem? @Markus GIRDLAND ?
Is there going to be a version of this software that actually works any time soon?
Thanks!
Best Regards, Dave
