FDigi
Dec 23, 2022 5:08 PM UTC
[bug]Clock Configuration problem in STM32H743ii after update Cube IDE.
I have updated from stm32cube IDE 1.10.1 to 1.11.0 . After update and open the .ioc file, clock configuration show some problem like the CPU max clock frequency i can't use 480MHz any more.
Do you know anything about this bug?
The H7 Package in CubeMX was updated too from 1.10 to 1.11.0
AScha.3
AScha.3Best answer
Dec 23, 2022 5:53 PM UTC
max clk to choose, depends on core voltage (set:range 0)
+ maybe: chip revision (try: V or Y )
AScha.3
AScha.3Best answer
FDigi
FDigiAuthor
Dec 23, 2022 6:27 PM UTC
thank you.
Changing the production revision solved my problem
