DViks.1
May 17, 2020 10:57 PM UTC
Anyone got STM32H7XX + I2S full-duplex master working?
I have tried to use STM32CubeMX and STM32CubeIDE to generate code. But in CubeIDE I can't create a SPI2_RX DMA Request. And in CubeMX I can't generate a Master Clock Output.
So I wonder if there is any handcrafted code anyone written to get this working? and how to accomplish this.
Is it intentional that stm32h7xx_hal_i2s_ex.c is empty? or is it that they just not had the time to do it?
If CubeMX or CubeIDE doesn't work. Is there any similar chip I can use instead, or can look how it's configuered to get this started?
Nesrine.JLASSI
May 18, 2020 8:55 PM UTC
Hello @DViks.1​
I can't reproduce the problem, could you please share your ioc file to check the issue.
Best regards,
Nesrine
DViks.1
DViks.1Author
May 18, 2020 11:36 PM UTC
That file is from STM32CubeMX
DViks.1
DViks.1Author
May 19, 2020 2:29 AM UTC
I have found 2 similar threads in the forum...
https://community.st.com/s/question/0D50X0000Ap3TK3/i2s-fullduplex-on-stm32h7-stm32cubemx-doesnt-produce-working-code
https://community.st.com/s/question/0D50X0000CArlTH/fullduplex-i2s-with-master-clock-output-on-stm32h7-in-stm32cubeide
All threads say that the hal / cube implementation for i2S for STMH7 is broken.
Looks like the HAL / Cube implementation for H7xx and I2S most probably has been broken for 3 years since the chip range first was introduced in 2016.
DViks.1
DViks.1Author
May 19, 2020 2:12 PM UTC
ok! In the file stm32h7xx_hal_i2s_ex.c it is stated...
                   ##### I2S Extension features #####
 The I2S Full duplex feature is not supported by this HAL Driver
...that had been good to know a lot earlier.
Is there any plans to make support for I2S with full-duplex?. Or is the I2S hardware broken/cripled in the STM32F7xx line?
Nesrine.JLASSI
May 19, 2020 2:41 PM UTC
Hello @DViks.1​
Thanks for the feedback, the I2S Full duplex feature will be available next STM32CubeMX version.
Best regards,
Nesrine
DViks.1
DViks.1Author
May 19, 2020 4:34 PM UTC
That sounds fantastic
