KSulli
Oct 30, 2020 9:56 AM UTC
Any option in CubeMX that allows for changing the stack size of the "Ethif" task ( INTERFACE_THREAD_STACK_SIZE)?
Hello, The stack size is defined by a macro definition, INTERFACE_THREAD_STACK_SIZE inside the "ethernetif.c" file located under: LWIP/Target.
I had to manually increase the size due to stack overflow and any new code generation via CubeMX overwrites those changes. Since code generation always defaults the size of INTERFACE_THREAD_STACK_SIZE to 350, I would hope that there would be a way to adjust it via CubeMX?
Khouloud OTHMAN
Khouloud OTHMANBest answer
Nov 9, 2020 4:28 PM UTC
Hi KSulli,
Backing to this problem, and since INTERFACE_THREAD_STACK_SIZE value is handled in the "ethernetif.c" file, STM32CubeMX later version doesn't overwrite the manual changes made by the user.
The .ioc file you have attached is created with an old 5.4.0 CubeMX version and that's why overwriting problem occurs . Please try newer version, that may be a workaround for your problem.
You will find linked STM32CubeMX version 6.0.1: https://www.st.com/en/development-tools/stm32cubemx.html
Regards,
Khouloud.
Khouloud OTHMAN
Nov 2, 2020 3:27 PM UTC
Hello KSulli,
Could you please attach your .ioc file or precise which MCU are you using ?
Thanks in advance,
Reagards,
Khouloud.
KSulli
KSulliAuthor
Nov 2, 2020 4:59 PM UTC
Hello Khouloud,
Please see the attached copy of my .ioc file for the STM32F765IIKx MCU.
Thanks very much for looking into it for me.
Best regards,
Kevin
Khouloud OTHMAN
Hi KSulli,
Regards,
Khouloud.
KSulli
KSulliAuthor
Nov 9, 2020 6:45 PM UTC
Hi Khouloud,
Many thanks for getting back to me with a potential workaround for this. I will give the newer version a try.
All the best,
Kevin
Khouloud OTHMAN
Nov 10, 2020 10:56 AM UTC
Hello KSulli,
Thank you for your feedback. Glad to know we are able to resolve the issue in a way that is satisfactory.
You're welcome anytime.
Regards,
Khouloud.
