DaveP
An internal error occurred during: "Launching Src". java.lang.NullPointerException
This is using STMCube and an STM32F4-discovery with an STM32f429I
Semer CHERNI
Semer CHERNIBest answer
Hi @Community member​
It seems that something have corrupt the original workspace.
Concerning the tutorials, I don't know which one you are referring to; but I advice you to give a look to this series.
Best regards,
Semer.
Semer CHERNI
Hello @Community member​
First let me thank you for posting and welcome you to the community.
Could you provide more detail about mentioned error:
  • Which tool version you are using
  • The steps you made to get to this error
  • The .log file you can find under the workspace in the .metadata folder
  • Maybe try to import your project to a new workspace
Kind regards,
Semer.
DaveP
DavePAuthor
Hi Semer,
Thank you for your response. I have actually gotten around the problem by removing all older versions of the IDE (1.5.1 and 1.11.0), installing the latest (1.11.2), and using a new workspace. Still not a clue as to why I could not, following the steps in the tutorials to create a workspace: identify the discovery board I am using (stm32f4-discovery) or the chip (stm32f429zi6tu), creating the code template, building a debug image, and trying to run the code resulted in the error message I referenced.
Any insight would be appreciated - I am in the process of learning to use the STM32 devices for a research project.
Best,
Dave
Semer CHERNI
Best regards,
Semer.
Hello @Community member​,
Could you please more details about the example you are using? Version of CubeIDE?
It is possible that this is due to a missing dependency or misconfiguration. Try to clean and rebuild the project. If this doesn't help, it could be due to this thread STM32CubeIDE - In-tool update issue! (Solved in 1.11.2)
DaveP
DavePAuthor
I did do a clean and rebuild to no avail. I finally uninstalled the versions I had tried, 1.5 and 1.11, and installed 1.12 and the problem went away.
Thanks for the support,
Dave
