JongOk Baek
An error occured while generate NetXDuo Code
I make a new product with NetXDuo for STM32H743.
But, it is included error code in RTE_Components.h
RTE_Components.h (A project)
/* USER CODE END Header */
 /* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __RTE_COMPONENTS_H__
#define __RTE_COMPONENTS_H__
/* Defines ------------------------------------------------------------------*/
/* STMicroelectronics.X-CUBE-AZRTOS-H7.3.3.0 */
#define FILEX_ENABLED
#define FX_SD_INTERFACE
NX_ETH_INTERFACE_ENABLED
#define LAN8742
#define THREADX_ENABLED
#define TRACEX_SUPPORT_ENABLED
#define NETXDUO_ENABLED
#endif /* __RTE_COMPONENTS_H__ */
RTE_Components.h (B project)
#define USBXDEVICE_ENABLED
#define UX_DEVICE_CONTROLLERS_ENABLED
#define UX_DEVICE_CDC_ACM
#define LAN8742
it is missing '#define' statement for 'NX_ETH_INTERFACE_ENABLED'.
Fortunately, the error does not occur becasue the RTE_Components.h file is not built.
Ghofrane GSOURI
Hello @JongOk Baek
First let me thank you for posting.
Could you please provide your IOC so that I can check your configuration and investigate further the issue?
I will be waiting for your feedback.
THX
Ghofrane
JongOk Baek
Dear Ghofrane,
Thanks for your reply.
I attached IOC file.
And please find it.
Best regards,
Ghofrane GSOURI
Hello @JongOk Baek
Thanks for your contribution.
Issue has been raised to dev team for fix .
Internal ticket  number :197472
BR,
Ghofrane
