PSui.1
A bug of STM32G4xx LL library
I reporte a bug of STM32G4xx LL library, the Definition of DMAMUX_LL_EC_REQUEST Transfer request in header file "stm32g4xx_ll_dmamux.h" as shown below.
#define LL_DMAMUX_REQ_FMAC_WRITE     0x0000006EU /*!< DMAMUX FMAC WRITE request */
#define LL_DMAMUX_REQ_FMAC_READ      0x0000006FU /*!< DMAMUX FMAC READ request  */
#define LL_DMAMUX_REQ_CORDIC_WRITE   0x00000070U /*!< DMAMUX CORDIC WRITE request*/
#define LL_DMAMUX_REQ_CORDIC_READ    0x00000071U /*!< DMAMUX CORDIC READ request */
But the STM32G4 Series reference manual is defined as below.
110 FMAC_Read
111 FMAC_Write
112 Cordic_Read
113 Cordic_Write
The HAL library is defined as follows.(stm32g4xx_hal_dma.h)
#define DMA_REQUEST_FMAC_READ        110U
#define DMA_REQUEST_FMAC_WRITE       111U
#define DMA_REQUEST_CORDIC_READ      112U
#define DMA_REQUEST_CORDIC_WRITE     113U
So it looks like that read and write are defined as the exact opposite in the LL library,include FMAC and CORDIC module.
Not only that, but a compilation error will be generated after generating the project, because there are no two macro definitions.
"LL_DMAMUX_REQ_MATRIX_READ"
"LL_DMAMUX_REQ_MATRIX_WRITE"
After the following modifications, can pass the compilation.
// LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_3, LL_DMAMUX_REQ_MATRIX_READ);
   LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_3, LL_DMAMUX_REQ_FMAC_READ);
// LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_4, LL_DMAMUX_REQ_MATRIX_WRITE);
   LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_4, LL_DMAMUX_REQ_FMAC_WRITE);
 Expecting official feedback.
Thanks.
Nesrine.JLASSI
Nesrine.JLASSIBest answer
March 19, 2020
​Hello all,
Thanks for the feedback,
It will be fixed next STM32CubeMX version.
Best regards,
Nesrine
PSui.1
PSui.1Author
Losing screenshots is frustrating.
I will check this issue and come back to you.
Which cube firmware version are you using ?
Can you please use the latest STM32CubeMx (V5.6.0)
PSui.1
PSui.1Author
Hi Imen DAHMEN
The firmware version STM32Cube_FW_G4_V1.1.0​. I think the MCU package version is lastest.
The CubeMX current version is 5.5.0.
Anyway, I try use the latest STM32CubeMx (V5.6.0).
PSui.1
PSui.1Author
Hi Imen DAHMEN
I have used the latest STM32CubeMX (V5.6.0) regenerate this project, and the MCU package version also upgraded to the latest version "STM32Cube_FW_G4_V1.2.0​."
But the bug is still not fixed.
Thank your for your contribution and reported issue.
After check, I confirm this issue and raise this internally for correction.
Best Regards,
Imen
PSui.1
PSui.1Author
Hi Imen DAHMEN
Thank you for your quick reply and looking forward to your confirmation.
Best Regards,
Peng​
Nesrine.JLASSI
March 18, 2020
The reported problem will be reviewed by our STM32CubeMX team, we will come back to you if there is any update.
Best regards,
Nesrine
Nesrine.JLASSI
March 19, 2020
​Hello all,
Best regards,
Nesrine
PSui.1
PSui.1Author
Hi Nesrine
Thank you for your reply.
Best Regards,
Peng​
