Pavel Krupets
6.7.0. STM32H745 doesn't have "Power Regulator Voltage Scale 0" in the list
I selected LDO power supply
But frequency is still limited to 400MHz.
Piranha
PiranhaBest answer
Principal III
December 11, 2022
Set the "Product revision" to "rev.V" and read the AN5337.
AScha.3
try just for test: use smps supply, scale 0 should be possible then.
Pavel Krupets
nope, I tried different regulators but 0 is never in the list
main thing is that according to specs 480MHz available only with LDO but no matter what I do, I couldn’t set frequency to 480.
Piranha
PiranhaBest answer
Principal III
December 11, 2022
Pavel Krupets
REALLY APPRECIATE YOUR HELP!!!
THAT SOLVED MY ISSUE!!!
I am on NUCLEO board, playing with collecting data, lifetime is of no concern
though ST should add this to error message when I am unable to set frequency to 480 MHz
KDJEM.1
Hello @Pavel Krupets​,
This issue is already reported in this post.
Sorry for this inconvenience.
Internal ticket number: 140578 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
KDJEM.1
This issue has been solved in the STM32CubeMX6.8.0.
Thank you for your contribution.
Kaouthar
