Mar 23, 2025 3:58 PM UTC
windows executable from Cubemonitor flow
Dear all,
haven´t yet found topic like this.
I would like to...(need) make a windows executable file / application from a Cubemonitor flow.
Any Idea if and how possible?
Thanks and have a great day!
    Pavel A.
    Mar 23, 2025 6:23 PM UTC
    Mar 23, 2025 6:25 PM UTC
    it´s not a request, it´s a question.
    thanks!  (sarcastic)
    Pavel A.
    Mar 23, 2025 8:23 PM UTC
    Answer: pretty much is possible. Depends on your motivation.
    Basically you need to wrap the CubeMonitor executables, javascript runtime, interface (USB?) driver, their dependencies together, zip that (or make a nice installer). Maybe make a custom launcher. Not a rocket science but takes some effort. This task is a good candidate for outsourcing to fiverr.
    Ufuk.Akkaya
    Jun 18, 2025 3:02 PM UTC
    We have a similar need. If necessary, the installation can be done manually. However, once the installation is complete, the user should not be able to view or modify the design. Is there a way to achieve this?
    Thank you, and good work.
    Andrew Neil
    Jun 18, 2025 3:11 PM UTC
    Would probably be better to start a new thread of your own, and give a full description of your actual use case, and what you actually need.
    You could always give a link to this thread, for reference.
    But I'm not sure this is the kind of thing ST intend the CubeMonitor to be used for ...
