NChan.7
Jan 17, 2023 8:46 PM UTC
The exe-config node can't extract variable from elf file
Hello, I followed the tutorial with just one variable (extracted from an elf) there was no problem the variable showed in the chart. But when I added another variable to the code and got a new elf. I went to the variable node to add the new variable but there's none (the first variable also gone). I tried with other elf files from other projects but it doesn't work either. Thank you in advance! (I'm using the CubeMonitor in Window10)
Richard.Chvr
Richard.ChvrBest answer
Sep 27, 2023 3:45 PM UTC
Closing the ticket as no update since a while
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Richard.Chvr
Feb 16, 2023 2:17 PM UTC
Hello @NChan.7​
Can you share your flow and elf file if possible.
Richard.Chvr
