May 10, 2025 6:52 AM UTC
Storing data from stm32 cube monitor graph
I want to store the stm32 cube monitor graph data or store the corresponding variable data in to xml sheet. How can I do that.
Jojo_
May 15, 2025 9:30 AM UTC
STM32CubeMonitor by default allows you to export graph data in JSON format.
You can then use an online tool to convert this JSON file into XML format.
