Richard.Chvr
Nov 23, 2023 11:28 AM UTC
STM32CubeMonitor v1.7.0 is available
Hello
A new version 1.7.0 of STM32CubeMonitor is available on st.com.
You can download it on https://www.st.com/en/development-tools/stm32cubemonitor.html
Click on "Get latest" to download the version 1.7.0.
What are the changes in this version ?
  • Node-RED® updated to the version 3.1, released in September 2023, with multiple improvements in the
    editor(1):
    • Notifications management for each tab
    • Bigger workspace
    • Lockable flow
    • Update context menu
    • Group improvement
    • Link to help in the node panels
    • Improvement of horizontal wiring
  • New format added to export .csv data:
    • The data can be organized in multiple columns, making importing to a spreadsheet very easy. In the
      array, each variable is listed in one column with a timestamp in the first column.
    • The details about data recording and display are available in the STM32CubeMonitor advanced
      features pages of the STM32 MCU wiki at wiki.st.com/stm32mcu.
  •  Dependencies updated:
    • The main change is the update of Electron® to 25.8.1 with Node.js 18.15.0.
    • The indirect dependencies are also updated.
Do not hesitate to create new posts if you have any question.
The STM32CubeMonitor team.
    David Littell
    Senior II
    Nov 29, 2023 2:44 PM UTC
    Will the .elf parser be improved at some point to handle large structures?
    Richard.Chvr
    Nov 30, 2023 8:58 AM UTC
    @David Littell , unfortunately no, release 1.7.0 was already available when you raised this issue.
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    David Littell
    Senior II
    Nov 30, 2023 2:29 PM UTC
    So, the soon-to-be-released 1.8.0 should include the fix, right?
    David Littell
    Senior II
    Dec 17, 2023 1:16 AM UTC
    Is there an expected release date for 1.8.0?
    Andrei Chichak
    Lead
    Jan 10, 2024 6:49 PM UTC
    Any chance of having the variables widget use the OS facilities to set the folder graphically rather than cut/paste?
    Andrei
