Apr 29, 2024 8:00 AM UTC
STM32CubeMonitor size of chart in dashboard
I use CubeMonitor V1.8.0 with my STM32G474QET device. Unfortunately the chart inside the dashboard is very small so I can`t work with it. Is there any possibility to set the size of the graph? The only thing I found is the duration in seconds, but that only changes the resolution but not the chart size itself.
Thanks for any recomendations.
Benedikt
    Richard.Chvr
    Richard.ChvrBest answer
    May 2, 2024 12:36 PM UTC
    Hello @berait
    You can configure the chart size in you flow while editing the node
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    Richard.Chvr
    Hello @berait
    beraitAuthor
    May 7, 2024 6:29 AM UTC
    Hi Richard,
    I somehow have not seen this setting, thank you for your hint
    regards, Benedikt
