acv_atr
Mar 23, 2022 12:17 PM UTC
STM32CubeMonitor Security/Credentials critical issues
Hi everyone.
I'm trying to secure STM32CubeMonitor Editor and UI as defined to Node-RED, but is not possible secure STM32CubeMonitor.
After define a user and password at settings.js (even only for STM32 CubeMonitor) the editor and UI breaks and are simply useless.
0693W00000KdjXFQAZ.pngThis is a critical issue nowadays, not been able to secure a webserver that can be exposed to remote access, to provide REST API's and so on...
Tested STM32CubeMonitor v1.3.0
In other hand, this features works perfectly on native Node-RED instances.
There is a known workaround to secure STM32CubeMonitor editor and UI with user-password login?
stephane.legargeant
Oct 31, 2022 4:46 PM UTC
Hi @Andrea cavani​
The release 1.5.0 is online. It should be possible now to secure the editor properly.
Please, let us know if it is ok with the new version.
Please note: In the default setting.js, the remote access is now disabled by default.
Best regards
Stephane
acv_atr
acv_atrAuthor
Mar 24, 2022 9:16 AM UTC
Hello everyone.
There are some possibility of getting an answer from STMicroelectronics people?
Anyone has facing this issue or have this need?
Thanks for your time and attention
acv_atr
acv_atrAuthor
Mar 30, 2022 10:45 AM UTC
Hello to everyone.
Does anyone know a wrokaround to this critical issue?
Thanks for your attention.
Best regards
Richard.Chvr
Mar 31, 2022 7:34 AM UTC
Hello @_acv_atr​
I tried using user and password at settings.js for both STM32CubeMonitor-1.3.0 and newly published 1.4.0 and didn't face any issue such as the one you mentioned (see attached settings.js). Can you detail your environment and the modification you made.
// Securing Node-RED
 // To password protect the Node-RED editor and admin API, the following
 // property can be used. See http://nodered.org/docs/security.html for details.
 adminAuth: {
 type: "credentials",
 users: [{
 username: "admin",
 password: "$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN.",
 permissions: "*"
 default: {
 permissions: "read"
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
acv_atr
acv_atrAuthor
Mar 31, 2022 11:24 AM UTC
Hello @Richard.Chvr​
Going in more detail:
OP: Ubuntu 20.04 desktop
CubeMonitor: v1.3.0
user: admin
password: admin_1234#
FLow: default from ST, after fresh installation
0693W00000LwQ4sQAF.pngEditor asking for password as expected:
Editor stuck after enter correct password:0693W00000LwQ5HQAV.png
Please consider flow and settings on attachment.
If you need further details, let me know.
Thank you
Richard.Chvr
Mar 31, 2022 1:18 PM UTC
@_acv_atr​
Thank for these details, I've tested this configuration on my ubuntu machine (I previously successfully tested it on windows) and I confirm the issue you face. Will investigate and come back to you.
ACava.1
May 2, 2022 9:49 AM UTC
@Richard.Chvr​
Any news or update about this subject?
Thanks for your support.
ACava.1
May 9, 2022 2:00 PM UTC
Hello @Richard.Chvr​ .
There is any update or workaround regarding this critical issue?
Thank your for your attention
Richard.Chvr
May 9, 2022 3:23 PM UTC
Hi @Community member​
Problem have been submitted to dev team. Still waiting for feedback .
Richard.Chvr
Sep 29, 2022 4:03 PM UTC
Hi @Andrea cavani​
Issue should be corrected in next release 1.5.0 that will come soon.
stephane.legargeant
Hi @Andrea cavani​
Best regards
Stephane
