sgran.1
Apr 6, 2020 10:20 AM UTC
STM32CubeMonitor and STM32CubeIDE - .axf ??
For using need .axf file, not found in my project((. How receive it file? May be need more IDE settings?
Thierry
ThierryBest answer
Apr 15, 2020 3:04 PM UTC
STM32CubeMonitor is tested on Linux, Windows and macOS.
After having double check, I do confirm there is a specific bug to copy/paste on macOS.
We will fix this bug in a future release.
Thanks for reporting this issue.
PLi.8
May 15, 2022 11:05 PM UTC
Hi.Thierry.
I have the same problem. I can load the .elf file generated by cubeIDE to Monitor the variables. but their value is always zero. however, I used cubeMX and MDK tested by axf file. the value is changing as I set. if there is any setting I need change in cubeIDE?
Thank you.
