Aug 11, 2025 7:41 AM UTC
STM32 Cube Monitor not able to parse ELF file
Currently I am facing a issue where my CUBE monitor is not able to parse the ELF files. It gets stuck at 10% completion while loading it. I have attached my workflow below:
The Error is as follows:
It will be very helpful if anyone can provide any insights as to what might be the problem.
Thanks,
Prishat
    Richard.Chvr
    Sep 4, 2025 8:02 AM UTC
    Hello @Prishat
    Can you share your elf file.
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    Ozone
    Principal
    Sep 4, 2025 8:10 AM UTC
    None of your screenshots is related to an ELF file.
    The ELF file is the generated executable, intended to run on the target.
    Richard.Chvr
    Sep 4, 2025 8:57 AM UTC
    @Ozone,
    ELF file is used as input of CubeMonitor to get the address of the variables that can be monitored.
    Please have a look to wiki: STM32CubeMonitor:How to extract address from ELF files
    Ozone
    Principal
    Sep 4, 2025 9:28 AM UTC
    That I know.
    And what happened to good old-fashioned map files ?
