Mar 24, 2020 9:55 AM UTC
STM Studio has "Point Viewer" feature which makes possible to plot an arbitrary variable Y as a function of second arbitrary variable X. Is this possible with STM32CubeMonitor? Can you propose solution?
Landry
LandryBest answer
Apr 3, 2020 1:53 PM UTC
Dear Oj,
You will find attached a flow ( VarViewer.json) where the variable "counter" as X and "counter2" as Y are displayed in a scatter graph.
What you will have to do when you will import the flow :
  • modify the configuration of nodes "variables" ( select your own variables ) , "acquisition out" - "acquisition in" (select your own probe ), "processing" ( select the variables node ) and "dual data" ( select the mapping X and Y with your own variables ).
I hope it will answer your needs.
Landry
Landry
Mar 24, 2020 11:12 AM UTC
Dear Oj,
There is a similar question already answered in the forum :
https://community.st.com/s/question/0D50X0000CDosGISQZ/is-there-a-method-to-plot-2d-data
Is it answering your point ?
OJ_itAuthor
Mar 25, 2020 8:55 AM UTC
Dear Landry,
I have to admit that I'm not sure does it answer. Maybe it does. I guess I have to study STM32CubeMonitor a lot more to understand how to do this.
This new STM32CubeMonitor seems very interesting because you can do so much with it but at the same time the learning curve is much steeper compared
to the STM Studio. Maybe at some point you could give some clear example how to realize STM Studio "Point Viewer" feature with the new STM32CubeMonitor?
Landry
LandryBest answer
Dear Oj,
Landry
OJ_itAuthor
Apr 6, 2020 6:35 AM UTC
Dear Landry,
Thank you for the example flow! Tested it and it works perfectly!
