Rob.Riggs
Senior
Jul 18, 2024 2:51 AM UTC
Running STM32CubeMonitor in a Container on Linux
As a Fedora user, finding that STM32CubeMonitor is only distributed for Linux as pair of .deb packages for Ubuntu was a disappointment. So I created a container to run it in. This may also help those running newer versions of Ubuntu LTS, which is incompatible with the supplied .debs.
https://github.com/mobilinkd/STM32CubeMonitor
I hope this is not needed for long and that ST will package this software for use on a wider range of Linux systems. Or maybe publish their own sets of containers for Linux.
    Richard.Chvr
    Aug 8, 2024 8:52 AM UTC
    Thank you @Rob.Riggs , unfortunately, there's no plan to support rpm packages as stated in this post .
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    Rob.Riggs
    Rob.RiggsAuthor
    Senior
    Aug 9, 2024 3:32 PM UTC
    @Richard.Chvr The ask is not for RPMs. The ask is for a neutral tar.gz or zip format. ST distributes all of their other tools for Linux this way. Only distributing it in .deb format severely restricts the usability of this tool.
