EAlek.11
May 11, 2022 1:20 PM UTC
Node "Single value" not working for Chart
In wiki i read about using "Single value" node for variables visualization in text frames like "Numeric" node and it working fine for it. But i cant to force to work it with "Chart" node. How it can be done?
Richard.Chvr
Richard.ChvrBest answer
May 16, 2022 3:17 PM UTC
Hello @EAlek.1​
ST chart could not be used as output of single value. If you want to plot only one variable, you can add another variables/processing nodes to select corresponding variable.
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Richard.Chvr
Hello @EAlek.1​
