Apr 2, 2025 9:44 PM UTC
Issue with Missing Acquisition Nodes in STM32CubeMonitor
I am experiencing an issue with STM32CubeMonitor on Windows 11 where some nodes, including acquisition out, are marked as "not found" and cannot be used.
I have found similar reports from other users:
https://community.st.com/t5/stm32cubemonitor-mcus/cubemonitor-acquitions-installing/td-p/660215
https://community.st.com/t5/stm32cubemonitor-mcus/missing-acquisition-nodes-on-macos/td-p/644151
I have tried the suggested solutions, such as running stlinkserver, but the issue persists. After starting stlinkserver, is there any additional setup required?
Has anyone solved this issue using a different approach?
Are there any additional steps required after starting stlinkserver?
Environment:
  • OS: Windows 11
  • STM32CubeMonitor Version:1.10.0
    AikuBest answer
    May 1, 2025 2:40 AM UTC
    Thank you for your support!
    I finally solved the issue. The root cause was the lack of Visual C++ Redistributable libraries.
    After installing the packages (I installed versions 2005, 2008, 2010, 2012, 2013, 2015–2022), the missing shared library error disappeared, and the problematic acquisition nodes started working correctly.
    Hopefully, this helps others who face the same issue!
    Richard.Chvr
    Apr 30, 2025 3:19 PM UTC
    Did you update from an older STM32CubeMonitor version or from scratch?
    Did you try uninstall/Install ?
    If still issue, can you launch STM32CubeMonitor.exe in a terminal a send the log.
    To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
    AikuAuthorBest answer
