How to write variable in cube-monitor?
Core issue: Clearly state that STM32CubeMonitor fails to write to the variable. Even though reading works normally and the address/type are correct, the write has no effect.
Items already ruled out: Tell the engineer that you have checked the address (consistent with the IDE debugger), type, Access Point, WFI/WFE, SWD frequency, and USB port, and have tried both the write panel and a custom flow.
Key evidence: Attach the debug log from the write panel (showing validity: true but the value unchanged), as well as the specific chip model (Cortex-M0).
