EAlek.11
Jan 10, 2022 3:06 PM UTC
How to change wingets location?
I searching the simple and usefull way to change wingets location for more flexible debug UI design. For example how to place the gauge first before and 20 pixels lower the chart on the dashboard?
0693W00000Hr7QyQAJ.pngThe flow looks like:0693W00000Hr7OPQAZ.png
Richard.Chvr
Richard.ChvrBest answer
Jan 11, 2022 11:25 AM UTC
HI
Fist you need to select dashboard on the right side
0693W00000HrEGCQA3.pngAnd then select layout to be able to modify widget location
0693W00000HrEFiQAN.pngThen you'll be able to place your widget where you want
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Richard.Chvr
HI
