OPare.1
Sep 8, 2020 10:12 AM UTC
How can I save the whole session into a file?
I was wondering how can I store the whole session into a file, which can be sent to someone else or maybe recovered after working in a different flowchart.
I see I can export the nodes chart, but the whole configuration of each node is lost using that option.
Best regards,
stephane.legargeant
Sep 8, 2020 11:54 AM UTC
Hello
You can export the complete flows by using the menu export and select the option "all flows" and then download. All the nodes will be saved.
Does it solve your point ?
Best regards
Stephane
stephane.legargeant
Hello
Best regards
Stephane
