pDABE.1
Jan 27, 2023 7:09 AM UTC
Hello, I am using Nucleo F446RE and the acquisition failed with STM32CuneMonitor. Every thing is ok with the prob, processing and variables (Leds green see screen shot) When I launch the Dashboard the start acquiistion button do no thing.
The code is a basic blinking LED and a free counter variable. The code runs well on the board. The list of variables is ok in STM32CubeMonitor.Thank you
KnarfB
Jan 27, 2023 9:04 AM UTC
Strange. Nothing at debug 1? Simplify your flow for debugging, e.g. remove BP bleu node.
hth
KnarfB
pDABE.1
pDABE.1Author
Jan 27, 2023 10:02 AM UTC
I already did it without success !! I tried aswell with only on chart and it does'nt works
No message at debug to.
Richard.Chvr
Feb 16, 2023 2:42 PM UTC
Hello
For sure BP bleu single value node can be removed and ST Chart linked directly to processing node. Can't see the variable you're monitoring in the Monitor-2 screenshot. Can you share a bit more informations about elf and flow?
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
