MFran.4
Senior
Jul 7, 2021 7:06 AM UTC
CubeMonitor still not seeing boolean values
Hello!
I already seen the post where it says that version 1.1.0 solves this problem. I'm using version 1.2.0 and booleans still not appear. Converting them to uint8_t obviously works but I read that this thing was fixed so maybe I'm missing something.
Thank you all!
Mirco
MFran.4
MFran.4Best answer
Senior
Oct 20, 2021 12:11 PM UTC
Just saw that, in stdbool.h, as I'm doing a project in C++, the stdbool's "true" and "false" are greyed out. Instead I get this:
/* Supporting _Bool in C++ is a GCC extension. */
#define _Bool   bool
Richard.Chvr
Aug 3, 2021 11:10 AM UTC
Hello @Community member​ ,
Did you define your own boolean type or did you use:
#include <stdbool.h>
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
MFran.4
MFran.4Author
Senior
Aug 24, 2021 6:06 AM UTC
Hi! I included stdbool.h as you wrote.
MFran.4
MFran.4Author
Senior
Oct 20, 2021 12:04 PM UTC
Hi! Any hints? I've changed project (so it's another flow) and I can't still see booleans. Still using CubeMonitor 1.2.0.
MFran.4
MFran.4AuthorBest answer
Senior
#define _Bool   bool
