Bertrand1
Senior
Oct 25, 2021 4:32 PM UTC
cubeMonitor project management
I am using CubeMonitor for the first time. I would like to know how to save and recall a project.
I can't find how to open a monitor project.
Bertrand
Richard.Chvr
Richard.ChvrBest answer
Oct 26, 2021 12:31 PM UTC
you can manage your flows files using project, but it's a bit more tricky:
Projects : Node-RED (nodered.org)
To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Richard.Chvr
Oct 26, 2021 12:23 PM UTC
Hello @Bertrand​
Your project is saved upon deploy button pressed.
If you're working on multiple flows, you can import/export them according to your needs user burger menu on the top right side of the window
Bertrand1
Bertrand1Author
Senior
Oct 26, 2021 12:27 PM UTC
Ok, import/export is the normal way to do this...I will dol with that.
I was expected open/save. ;)
Bertrand
Richard.Chvr
