Wrong debugger
I have just updated stmcubeidx to 2.3.0 . Its seems to work except the debugger connection is wrong. It thinks it is using J-Link but it should be ST-Link. How can I make that change to the debug configuration ?
SEGGER J-Link GDB Server V9.78 Command Line Version
JLinkARM.dll V9.78 (DLL compiled Sep 16 2026 16:25:20)
Command line: -port 2331 -s -device STM32F407VE -endian little -speed 4000 -if swd -vd
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: on
Init regs on start: off
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: STM32F407VE
Target device parameters: none
Target interface: SWD
Target interface speed: 4000kHz
Target endian: little
Connecting to J-Link...
