mehmet.karakaya
why no error for multiple definition of a variable
hello dear forum
accidentally i define same global variable in two different c file
why I havent got any error
thank you
C files are their own compilation unit. Other C files cannot see variables in them unless they are defined in a header (as extern, in this case).
Edit: above only applies if they're declared static.
Nikita91
Lead II
June 24, 2021
An the linkers have different behaviour:
some allocates a variable for each source file, others only allocates one...
