PMaro
where .ide.log file is save and can i change this folder
I import a project , in a different workspace (change folder) after i rename the project with new name, but every time i launch this project a old folders of old project is generated with inside .ide.log file of current session.
What can i do to solve the problem?
Cartu38 OpenDev
Graduate II
July 1, 2021
Not sure to get your point ... you're mixing .ide.log which is a trace / log file and project sutff ... I'm not not about your issue so.
"i launch this project" ... what do you mean by "launch" ? Debug session launch, project generation / update Thanks Device Configuration tool, ... if Eclipse world I don't know what is project launch ...
PMaro
PMaroAuthor
Thanks Cartu38 i solved the problem creating a new project
CJeff.2
February 14, 2023
For anyone else that stubbles here, I had the same issue as described above.
The solution was to edit the xml found in your workspace at "\.metadata\.log4j.xml" then replace the reference to your pervious workspace with your current name.
