Raytheon
Where can i set the ROM adress like KEIL in stm32cubeide?
DEAR ALL:
Where can i set the ROM adress like KEIL in stm32cubeide?like follow picture!
November 1, 2019
Not using the tool. Look at the Linker Script
Raytheon
RaytheonAuthor
Sorry,what do you mean the  Linker Script,is Instructions?​
November 3, 2019
Linker scripts describe the memory placement and usage expectations. KEIL generates a Scatter File​ from the GUI settings. Try searching on the "linker script" term if unfamiliar
Cartu38 OpenDev
Graduate II
November 3, 2019
*.ld file(s) is(are) linker script file(s). All memeory mappings are defined into
Raytheon
RaytheonAuthor
​Yse ,I find *.ld file(s),and if i can change the start ROM adress directly?
