Variable Substitution in Debug Configuration
In Codewarrior 11.x under the debug configuration C/C++ Application section I can enter "${BuildLocation}/PE-15B00.elf" and that debug configuration is used for all my different build configurations. In STM32CubeIDE, when I try to use variables in this section they are not expanded. Also, I cannot find an equivalent to "${BuildLocation)" in the STM32CubeIDE variable list. For the most part I only need one debug configuration for my debug and release configurations but STM32CubeIDE is forcing me to use 2. On top of that I have a bootloader build config and a firmware build config for my projects so I now have 4 debug configs when 1 would do. Has anyone found a way around this? Thanks.
