Senior
Usart Multiprocessor
I can not find any example for Usart Multiprocessor, It does not work.
I config on CubeMx and
HAL_MultiProcessor_EnableMuteMode(&huart1);
HAL_MultiProcessor_EnterMuteMode(&huart1);
put this 2  lines.
nimaltdBest answer
Senior
After doing configuration on Cube and setting Address bit to 7 bits, The master should send first byte (address) or by 0x80. for example if the slave address is 0x01, the master should send 0x81.
but now i can not send data from slave to master. i am working on it...
slave code:
main()
HAL_UARTEx_ReceiveToIdle_DMA(&huart1, buf, sizeof(buf));
while (1)
Senior
nimaltdAuthor
Senior
Anyway, I have found the solution.
Andrew Neil
@nimaltd  Please share the solution for the benefit of others who may come here with the same question.
Then mark that as The Solution.
nimaltdAuthor
Senior
hello @MA4 . thanks for your answer. but it is nit my topic. I could not find anything here
nimaltdAuthorBest answer
Senior
slave code:
main()
while (1)
