Update CubeIDE fails missing public key
Updating the cubeide generates this error:
An error occurred while collecting items to be installed
session context was:(profile=STM32CubeIDE, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Result of processing steps.
OK
OK
OK
Public key not found for 70b824d9a6b4ae29.
OK
I could just intall the latest version, but I assume there is a way to fix this.
Thanks,
Jamie
    Rim LANDOLSI
    Rim LANDOLSIBest answer
    Hello @j1s1e1 ,
    Thank you for your contributions and for your detailed explanations.
    The issue has been reported to STM32CubeIDE development team.
    Internal ticket number: 159507(This is an internal tracking number and is not accessible or usable by customers).
    I will keep you posted with updates, and I hope that this answered your question.
    Regards,
    Rim
    Rim LANDOLSI
    Hello @j1s1e1 ,
    Thank you for posting!
    Which STM32CubeIDE version you have updated?
    Thanks,
    Rim
    j1s1e1Author
    Hi Rim --
    I have STM Cube IDE 1.9.0.  I see upgrades that go up to 1.13.0.  I did try both update to latest and update to next in case multiple steps were required.  Additional details are listed below.
    Thanks,
    Jamie
    *** Platform Details:
    *** System properties:
    applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
    awt.toolkit=sun.awt.windows.WToolkit
    ds.delayed.keepInstances=true
    ds.delayed.keepInstances.default=true
    eclipse.application=org.eclipse.ui.ide.workbench
    eclipse.buildId=Version 1.9.0
    eclipse.commands=-os
    win32
    -ws
    win32
    -arch
    x86_64
    -showsplash
    -launcher
    HDaji.1
    Senior
    I also have CubeIDE update problem. However, the error is different.
    Problems downloading artifact: osgi.bundle,org.eclipse.equinox.common,3.17.100.v20230202-1341.
    Error reading signed content:C:\Users\xxx\AppData\Local\Temp\signatureFile9190832969811238731.jar
    An error occurred while processing the signatures for the file: C:\Users\xxx\AppData\Local\Temp\signatureFile9190832969811238731.jar
    Problems downloading artifact: osgi.bundle,org.eclipse.text.quicksearch,1.1.500.v20230129-1959.
    Error reading signed content:C:\Users\xxx\AppData\Local\Temp\signatureFile5145962442517373072.jar
    An error occurred while processing the signatures for the file: C:\Users\xxx\AppData\Local\Temp\signatureFile5145962442517373072.jar
    My CubeIDE is build info:
    STM32CubeIDE
    Version: 1.7.0
    Build: 10852_20210715_0634 (UTC)
    OS: Windows 10, v.10.0, x86_64 / win32
    Java version: 11.0.10
    MechMan
    Explorer
    I have the same problem. Do you have solution?
    Rim LANDOLSI
    Hello @j1s1e1 ,
    Regards,
    Rim
    Brian H
    Senior
    Why is this marked as "solved"?  The accepted solution has no useful information other than "we know about the problem and will keep you updated."  How about an update?  The least you could've done is provide the link to download the latest CubeIDE installer, which is here (requires STM login or PII).
    #metoo also with CubeIDE 1.9.0
    OK
    OK
    OK
    OK
    Same problem with Update to IDE 14.
    OK
    OK
    Public key not found for 5c28247a08c3bba7.
    OK
    OK
    OK
    OK
