Unable to update software packs
I am unable to update embedded software packages.
To update I select "Manage embedded software packages" menu item. Packages manager window opens. I see "Check Firmware & Software. Download File updaters.zip" but progress bar stays at 0 bytes. After a while error "Problem during Download of File" is shown. At the top of Software Packages manager I see "Releases Information was last refreshed 18277 days ago".
I managed to find ide log and there are the following errors in it:
2020-01-17 00:27:57,168 [INFO] Updater:886 - Updater Version found : 5.5.0
2020-01-17 00:27:57,210 [INFO] ApplicationProperties:181 - Using Application install path: C:\ST\STM32CubeIDE_1.1.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_5.5.0.201912201511
2020-01-17 00:27:58,512 [INFO] MainUpdater:2230 - connection check result : 10
2020-01-17 00:27:58,512 [INFO] MainUpdater:2874 - Updater definition file requires update
2020-01-17 00:27:58,512 [INFO] MainUpdater:236 - Updater Check For Update Now.
2020-01-17 00:27:58,519 [INFO] MicroXplorer:420 - Change Database Version : DB.5.0.50
2020-01-17 00:27:58,534 [INFO] MainUpdater:2230 - connection check result : 10
2020-01-17 00:27:58,534 [INFO] ServerAccessManage:348 - Download File updaters.zip
2020-01-17 00:27:58,534 [ERROR] ServerAccessManage:412 - IOException during http download : C:\Users\Р�?митрий\.stm32cubemx\plugins\updater\temp\updaters.zip.tmp (Си�?теме не удает�?�? найти указанный путь)
2020-01-17 00:27:58,612 [ERROR] ServerAccessManage:517 - Problem during Download of File : updaters.zip.
2020-01-17 00:27:58,850 [INFO] ServerAccessManage:348 - Download File updaters.zip
2020-01-17 00:27:58,850 [ERROR] ServerAccessManage:412 - IOException during http download : C:\Users\Р�?митрий\.stm32cubemx\plugins\updater\temp\updaters.zip.tmp (Си�?теме не удает�?�? найти указанный путь)
2020-01-17 00:27:58,883 [ERROR] ServerAccessManage:517 - Problem during Download of File : updaters.zip.
2020-01-17 00:27:58,964 [INFO] LoadServerUpdatesThread:301 - End of LoadServerUpdate Thread
2020-01-17 00:27:59,235 [INFO] CheckServerUpdateThread:92 - End of CheckServer Thread
Why does updater try to save temporary file into folder C:\Users\Р�?митрий instead of my user folder C:/Users/Дмитрий ?
thanks,
Dmitri
