Yasin Yelkovan
Tulip Icon
Do you know the meaning of this icon (I think Tulip)?
Thanks.
Yasin Yelkovan
Yasin YelkovanBest answer
Hi Pavel,
Thank you for your reply. I have solved this problem.
Actually, the link did not help me, but the spirit is similar.
I tried restoring the default settings. Right click on the corresponding file and then get to the "Resource Configuration" tab and select "Reset to Default" option. It worked for me.
Kindly
Pavel A.
It is not tulip. It is a little wrench. Indicates that the folder has overriding build settings inherited from its parent.
https://stackoverflow.com/questions/11796235/what-is-the-meaning-of-this-decorated-folder-icon-in-eclipse-cdt-project-explore
Yasin Yelkovan
Yasin YelkovanAuthorBest answer
Hi Pavel,
Kindly
