Trouble Using RTOS Aware Debugging with ThreadX
I'm having trouble enabling RTOS proxy for debugging. I followed the following tutorial:
https://www.youtube.com/watch?v=iRaiMvYZ08o
I get the following error:
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:60000
Error message from debugger back end:
Remote replied unexpectedly to 'vMustReplyEmpty': timeout
STM32CubeIDE v2.0.0
STLink connected with SWCLK and SWDIO with up to date firmware
STM32H725 custom board
Tested on new project generated using CubeMX
Here are my debug configuration settings:
Please let me know if you require any additional information.
Thanks in advance!
Hello @zmasmoudi
I reproduced the debug session with Nucleo-H723ZG and it works correctly.
I recommend connecting your custom board with STM32CubeProgrammer and erasing the memory, then restarting the debug session.
Please find in attachment my debug configuration.
Thanks.
Mahmoud
Hello @zmasmoudi
Let me thank you for posting and welcome to the ST Community.
For more investigation, could you please provide your Ioc.File.
Thanks.
Mahmoud
zmasmoudiAuthor
Hello Mahmoud
Thanks for the welcome and the quick response!
I've attached the .ioc file for a minimally reproducible example. I am getting the error with the auto-generated code without any modification (except clock init).
Hello @zmasmoudi
Thanks.
Mahmoud
