TNils.1
Transfer code from IAR to CubeIDE?
Hi
I have been requested to redesign a current product using an ST32F405RG where the software was developed in the IAR IDE.
This is mainly a HW update that requires only a little bit of SW changes.
Unfortunately the IAR IDE is not available. Hence, I wonder if it is possible/feasible to use/transfer the code/files from the IAR environment and use them in ST's CubeIDE?
If possible, how cumbersome can I expect it to be?
Thanks!
It should be quite manageable.
TNils.1
TNils.1Author
Great, thanks!
TNils.1
TNils.1Author
If it hadn't been for the great mess in the original files, migrating via Atollic Truestudio made it very manageable ;)
