Theme drop down greyed out
HI,
I'm using: windows 11, STCubeIde 1.18.1 on a fresh installation
I tried to:
  • Open org.eclipse.ui.workbench.prefs: everything here was comment out, I added a line "themeid=org.eclipse.e4.ui.css.theme.e4_dark"
  • Manually Deleted .metadata
  • Searched CubeIDE plugins/ directory for *theme: found only "org.eclipse.e4.ui.css.swt.theme"
  • Tried running stm32cubeide.exe -clean
  • Tried to install a theme plugin from market place, pointless as I can not select it from drop down after the installation
  • Restart windows
  • Reinstall STcubeide
Any ideas?
Semer CHERNI
Hello @JoseVidal
First let me thank you for posting.
This misbehavior is linked to ECLIPSE which is the base of the STM32CubeIDE.
I advise you to address to the ECLIPSE community for info.
BR,
Semer.
