Aishwarya
Apr 12, 2020 12:37 PM UTC
The program pauses and refuses to run after access multiple breakpoints access warning (handle_vCont_t, Thread already stopped)
I got with the CUBE IDE the following problem, at some random point in the program, the Debugger halts and throws the following error:
It occurs several times a weak and I didn't found a solution to this
MPaga.1
Mar 19, 2021 1:06 PM UTC
Hi Aish,
I'm experiencing the very same problem and can't find a cause. Since some time has passed, I'm wondering if you have found a solution or some mitigation. Thank you.
