SWV Timeline error -500000000
when I am plotting data with SWV timeline, the timeline randomly plots -500000000 or lower values, while plotted variable does not drop that low. Don't you know, where could be the problem? I did the easiest program, but the SWV still has this error.
The frequency of SWV is set correctly to 170MHz.
