cjaya.1
strange behaviour on STM32Cube IDE 1.9.0. In the debugging mode,if I wanted "step into" the function within the switch statement it just skip and does not "step into" the function. It is very strange. Any one can help this. very much appreciated. Tha
September 26, 2022
Not clear what part you're using.
Would suggest you turn OFF optimization if you want more linear-flow of code.
Perhaps generate a disassembly or code vs assembler, and WALK that to understand the flow/expectations.
cjaya.1
cjaya.1Author
Thank you for the reply. much appreciated. I am using the ST link v2 debugger. I am new to the STM32 Cube IDE where can I find to turn OFF optimization. And how do I generate disassembly. I have written in c using HAL libraries.
