KStew.1
STMCubeIDE 1.13.1 (GCC11) with optimizations off not allowing me to step through line by line
  I recently updated to 1.13.1 and haven't needed to do much debugging but now I am trying to debug and I have run into an issue that the debugger won't step over each line of code. When I step at a breakpoint it jumps to the next breakpoint instead of the next line of code. I moved back to STMCubeIDE 1.12.1 because it allows me to step line by line. Any thoughts on how I can get STMCubeIDE 1.13.1 to step through properly?
    Semer CHERNI
    Hello @KStew.1
    First let me thank you for posting.
    I am not able to reproduce this issue from my side. Therefore, could you provide a minimalistic project which contain this behavior for analysis.
    KR,
    Semer.
    KStew.1
    KStew.1Author
    I haven't created a minimalistic project yet - but I find that the debugger is able to sequentially step through the code until the RTOS (FreeRTOS v10.5.0) is running. I tried with STM32 v1.12.1 and it steps through line-by-line when the RTOS is running.
