StmCube Ide 1.16 cannot use for debugging STM32L5
I just try using Nucleo L522ZE-Q and compile example code
after i debug it, somehow it cannot write the file to the flash
and the trace is not set properly
after i downgrade the IDE using 1.14 it can work properly no
please fix the new IDE, i didn't want to use multiple version of cube IDE
STTwo-32
STTwo-32Best answer
Hello @Azwar and welcome to the ST Community.
Are you having the same limitation number 189229 on the https://wiki.st.com/stm32mcu/wiki/STM32CubeIDE:STM32CubeIDE_errata_1.16.x#STM32L5
And if so, can the workaround mentionned with the debug issue "Use OpenOCD as a debug probe" solve your issue.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
AzwarAuthor
Yes, it work now
