STM32L476 + ST25RU3993
When I tried to start my device using the sample code provided by the manufacturer, I received the error messages "SetBaseFrequency not working" and "PLL not working". I have confirmed that the device's crystal is functioning properly and the MCU is working normally. What could be the possible reasons for this issue?
    Issamos
    Hello @Alex_tw
    Could you please add the exemple, the visions of the firmware that you are using (better to update them). So that other members of community and can test and may help you finding solutions.
    Best regards.
    II
    Alex_twAuthor
    Hi,Issamos
    Thank you for your suggestion.firmware visions : 3.2.1.0
    sample code : ST25RU3993_FW_v3.2.1.0_Eval.bin
    Issamos
    Hello again @Alex_tw
    I suggest you to open your project using CubeMX and verify your clock configuration are compatible with your board or not.
    Best regards.
    II
