Stm32h753i-eval2 USB Host FS
I need help generating an .IOC file through the cube generator. What I need is USB Host FS. I'm having trouble getting it to work, specifically, there's no voltage on the VBUS output.
I want to mention that I was able to create a USB Host HS that works and outputs voltage.
Thank you!
Itzik
    ikogmanBest answer
    Thank you all for your help!!
    I wasn't able to create an IOC file such that, but I solved it by:
    1) Using a ready example that works
    2) Use our CUSTOM BOARD and generate such IOC file worked.
    I really appreciate your assistance!
    Ghofrane GSOURI
    Hello @ikogman
    First let me thank you for posting.
    1- Create a New Project:
    Select your STM32H753I-EVAL2 from the board selector .
    2- Configure USB Host FS:
    Go to the Peripherals tab.
    * Enable USB_OTG_FS under the Connectivity section.
    * Set the mode to Host Only.
    3- Enable VBUS Sensing:
    In the configuration settings for USB, ensure that you enable VBUS Sensing (typically PA9).
    This is crucial for detecting when a USB device is connected and supplying power.
    If VBUS sensing is enabled but not functioning, try disabling it and manually controlling the VBUS pin (PA9) as a GPIO output set to high.
    4- Clock Configuration:
    Make sure that the clock settings are properly configured to provide adequate power to the USB peripheral.
    5- Generate Code:
    Click on Project > Generate Code to create your .IOC file and associated project files.
    I invite you to read this  document which provides guidelines on USB hardware configurations and might offer additional insights into your setup : AN4879 the following question is asked "In order to manage the VBUS sensing for USB device, are there any recommendations for the resistor bridge values?"
    THX
    Ghofrane
    ikogmanAuthor
    Hi @Ghofrane GSOURI ,
    Thank you for your assistance. Following your solution, I have encountered a new issue:
    I disabled VBUS sensing, and now I am using PA9 as a GPIO output set to high. I do see that green LED10 is turned on, but I'm only measuring 2.8V on VBUS. When checking directly the PA9 pin, it is 3.3V.
    I need help to get 5V on VBUS.
    Thank you!
    Itzik
    Pavel A.
    In host mode you need a 5V & 100 mA (at least) power source for the devices. You don't get VBUS directly from the STM32 pin. Rather the pin controls  (turns on/off) the power supply that provides Vbus.
    Please read the user manual for your board and find how to use the USB ports in host mode.
    Or better find in the ST software package a ready example program for USB in host mode and play with it (keep a fire extinguisher handy ))
    ikogmanAuthorBest answer
