STM32H723 GCC compiler Optimization problem
STM32CubeIDE 2.1.1: My program works if I choose the GCC compiler “none” optimization and it doesn’w work if I select any other optimization; anyone may help me ?
Thank you
Andrew Neil
Andrew NeilBest answer
This typically means that there is a flaw (or flaws) in your code - it’s relying on something which the C language does not guarantee.
Probably the commonest is omitting/forgetting volatile where it's needed.
Relying on timing of the C code is another.
The -Og level should give you good debuggability - see here.
You could try that …
Your could also try printf-style debugging to see where your code execution differs from what you intended
Andrew Neil
carloVAuthor
Thank you, I need the max speed...is there a fast way to identify where the problem comes ?
CarloV
Andrew Neil
No.
You’re just going to have to debug it to see what’s going wrong.
You could start with a code review to check volatile usage, timing dependencies, etc.
As well as the software debugger, use a scope or logic analyser to see what happens with/without the optimisation.
